Debug View
The Debug View allows you to manage the debugging or running of a program in the workbench. It displays the stack frame for the suspended threads for each target you are debugging. Each thread in your program appears as a node in the tree. It displays the process for each target you are running.
If the thread is suspended, its stack frames are shown as child elements.
Debug View
The Execution Control Commands allow you to debug your program, starting, stopping and stepping through the code.
Debug View Commands
Command
Name
Description
Availability
Automatic
Configures the debug view to switch layout between a tree and a breadcrumb viewer automatically when the view is resized.
View action
Auto-Expand Breadcrumb
Configures the Debug Breadcrumb Drop-down to automatically expand elements when opened.
View action
Breadcrumb
Configures the debug view layout to use a breadcrumb viewer.
View action
Copy Stack command in context menu
Copy Stack
Copies the selected stack of suspended threads as well as the state of the running threads to the clipboard.
Context menu
Disconnect button
Disconnect
Disconnects the debugger from the selected debug target when debugging remotely.
Context menu and view action
Drop to Frame
This command lets you drop back and reenter a specified stack frame. This feature is similar to "running backwards" and restarting your program part-way through.
To drop back and reenter a specified stack frame, select the stack frame that you want to "drop" to, and select Drop to Frame.
Some caveats apply to this feature:
  • You cannot drop past a native method on the stack.
  • Global data are unaffected and will retain their current values. For example, a static vector containing elements will not be cleared.
Note: This command is only enabled if the underlying VM supports this feature.
  Edit [configuration name]... Opens the launch configuration dialog on the associated launch configuration, allowing you to make changes. Context menu
  Edit Step Filters Opens the Step Filtering preference page to allowing editing of step filters Context menu
Edit Source Lookup Edit Source Lookup Opens the source lookup dialog, allowing you to make changes. Context menu
  Filter Package Adds the containing package for the type from the current suspended execution to the listing of step filters Context menu
  Filter Type Adds the type from the current suspended execution to the listing of step filters Context menu
  Find... Opens the debug view element searching dialog. Context menu
  Lookup Source Forces source lookup to take place Context menu
  Open Declared Type Opens the declared type for the selected stack frame in a new editor. Context menu
  Open Declared Type Hierarchy Opens the type hierarchy for the declared type of the selected stack frame. Context menu
Properties
This command displays the properties of the selected launch. It also allows you to view the full command line for a selected process.
Context menu
Relaunch command in context menu
Relaunch
This command relaunches the selected debug target.
Context menu
Remove All Terminated Launches button
Clears all terminated debug targets from the view display.
Resume button
Resume
Resumes a suspended thread.
Context menu, Run menu and view action
Show Monitors Show Monitors
This option can be toggled to display or hide monitors.
Note: this command will only display monitor information if the underlying VM supports it.
View action
Show Qualified Names button
This option can be toggled to display or hide qualified names.
View action
Show System Threads Show System Threads This option can be toggled to display or hide system threads View action
Show Thread Groups Show Thread Groups This option can be toggled to display or hide thread groups View action
Step Into button
Step Into
Steps into the highlighted statement.
Step Over button
Step Over
Steps over the highlighted statement. Execution will continue at the next line either in the same method or (if you are at the end of a method) it will continue in the method from which the current method was called.
The cursor jumps to the declaration of the method and selects this line.
Run to Return button
Step Return
Steps out of the current method. This option stops execution after exiting the current method.
Suspend button
Suspend
Suspends the selected thread of a target so that you can browse or modify code, inspect data, step, and so on.
Terminate button
Terminate
Terminates the selected debug target.
Terminate All command in context menu
Terminate/Disconnect All
Terminates all active launches in the view.
Context menu
Terminate and Relaunch Terminate and Relaunch Terminates the selected debug target and relaunches it. Context menu
Terminate & Remove command in context menu
Terminate and Remove
Terminates the selected debug target and removes it from the view.
Context menu
Tree
Configures the debug view layout to use a tree viewer.
View action
Step with Filters button Use Step Filters Toggles step filters on/off. When on, all step functions apply step filters. Context menu, Run menu and view action
Debugger
Java views
Local debugging
Remote debugging Changing debugger launch options
Connecting to a remote VM with the Remote Java application launch configuration
Disconnecting from a VM
Launching a Java program
Preparing to debug
Resuming the execution of suspended threads
Running and debugging
Stepping through the execution of a program
Suspending threads Debug Preferences
Views and editors
Run Menu
