Terminate and Remove
Select the Terminate and Remove command [
] to terminate the launch associated with the selected debug target and remove it from the Debug View.
Debugger
Local debugging
Remote debugging
Changing debugger launch options
Connecting to a remote VM with the Remote Java application launch configuration
Disconnecting from a VM
Launching a Java program
Preparing to debug
Resuming the execution of suspended threads
Running and debugging
Stepping through the execution of a program
Suspending threads
Debug View
Debug preferences
Execution Control Commands
Relaunch
Remove All Terminated
Terminate
Terminate/Disconnect All
Terminate and Relaunch
