Drop to Frame
Select the Drop to Frame command [ Drop to Frame ] to re-enter the selected stack frame in the Debug View.
Note this command is only available if the current VM supports drop to frame and the selected stackframe is not the top frame or a frame in a native method.
Debugger
Local debugging
Remote debugging Changing debugger launch options
Connecting to a remote VM with the Remote Java application launch configuration
Disconnecting from a VM
Launching a Java program
Preparing to debug
Resuming the execution of suspended threads
Running and debugging
Stepping through the execution of a program
Suspending threads Debug View
Debug preferences
