![]() This page is used to control various Swing > Layouts options. Default layout managerThis preference controls the default layout manager that Swing Designer uses for any new frame or panel. The default is to use the implicit layout manager already in effect for each container (e.g., BorderLayout for JFrames and FlowLayout for JPanels). Layouts to useThis preference controls the layouts which can be selected in the
default layout manager and also which layouts are available in the
Design editor page. Containers automatically use layout manager type of parentThis preference determines whether new panels will use the layout manager of their parent's by default. Create variable for Layout using patternThis preference determines what pattern will be used to generate layout variables. The following styles are supported:
