General
The property table has been overhauled to avoid jumps after editing a property and to hide the tool-tip again when the mouse wheel is scrolled. Additionally, the SWT-based buttons have been replaced by pure GEF-based buttons to allow for a better integration into the table.
1.19 and older
1.20 and newer
Palette contributions may now also use SVGs as icons. If both an SVG and a PNG exist, the SVG file takes precedence if and only if SVGs are supported by the current Eclipse version.
Swing
  • Added conversion support for java.awt.Cursor, java.awt.Font and java.awt.ComponentOrientation in the Customizer.
SWT
  • Support for SVGs as image data if using Eclipse 2025-06 or newer.
Image Chooser with SVG selection
What’s new - v1.19.0
