The Value Specification XText editor uses the XText technology.
The textual editor allow to create/edit some types of Value Specification:
org.eclipse.uml2.uml.LiteralBoolean
org.eclipse.uml2.uml.LiteralUnlimitedNatural
org.eclipse.uml2.uml.LiteralInteger
org.eclipse.uml2.uml.LiteralReal
org.eclipse.uml2.uml.LiteralNull
org.eclipse.uml2.uml.LiteralString
org.eclipse.uml2.uml.InstanceValue
org.eclipse.uml2.uml.OpaqueExpression
This fonctionnality is implemented through several plugins:
UmlValueSpecificationScopeProvider
for the custom scoping of org.eclipse.uml2.uml.InstanceValue
displaying the org.eclipse.uml2.uml.InstanceSpecification
available in the model.
DefaultXTextDirectEditorConfiguration
for the Value Specification edition.
SetCommand
of the Value Specification in its container.
StyledTextReferenceDialog
that allows do define the component to edit the Value Specification in a widget in the properties view.
The default grammar of the XText parser for the Value Specification is the following:
(visibility)? (name'=')? value
The values accepted for the differents attributes are the following:
Attribute | Required | Values accepted |
visibility | No |
name | No | String representing an ID (i.e. XText grammar: '^'?('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')* ) |
value | Yes |
If the text filled is not compatible with the grammar of XText parser, an OpaqueExpression
will be created.
The XText parser for Value Specification is not restrictive with the text filled, i.e. the different features setted on an existing Value Specification will be kept if possible.
For example: If an existing Value Specification is a LiteralBoolean
named 'testBoolean' with the visibility 'public' and the value setted to true
, the text +testBoolean=false
and false
have the same result: the value of LiteralBoolean
existing will pass to false
(the name and the visilibity don't change).
The XText parser reacts differently instead of the type of the Value Specification's container:
If the type of Value Specification's container is not defined, the default behaviour will be applied.
Here, some examples:
Text filled | Namely | Created ValueSpecification | |||
Type | Visibility | Name | Value | ||
+testInstanceValue=InstanceSpec1 | 'InstanceSpec1' is an InstanceSpecification existing in the model |
InstanceValue |
public | testInstanceValue | 'instance' attribute of InstanceValue is a reference to the existing InstanceSpecification named 'InstanceSpec1' |
No InstanceSpecification exist in the model |
OpaqueExpression |
public | +testInstanceValue=InstanceSpec1 | ||
+testBoolean=true | LiteralBoolean |
public | testBoolean | true |
#testUnlimitedNatural=5 | LiteralUnlimitedNatural |
protected | testUnlimitedNatural | 5 | |
~testInteger=-8 | LiteralInteger |
package | testInteger | -8 | |
-testReal=12.34 | LiteralReal |
private | testReal | 12.34 | |
~testNull=null | LiteralNull |
package | testNull | null |
-testString="foo" | LiteralString |
private | testString | foo | |
##testString="foo" | OpaqueExpression |
public | ##testString="foo" |
If the type of Value Specification's container is setted, the same text filled will be have different behaviour depending to the type. In fact, the value filled must be consistent to the type, otherwise an OpaqueExpression
will be created.
The different types corresponding to LiteralSpecification
are the following:
LiteralSpecification | Types corresponding |
LiteralBoolean |
LiteralInteger |
LiteralReal |
LiteralString |
Text filled | Value Specification's container type | Created ValueSpecification | |||
+testBoolean=true | PrimitiveTypes::Boolean | LiteralBoolean |
PrimitiveTypes::Integer | OpaqueExpression |
public | +testBoolean=true | ||
-testUnlimitedNatural=8 | PrimitiveTypes::UnlimitedNatural | LiteralUnlimitedNatural |
private | testUnlimitedNatural | 8 |
PrimitiveTypes::Integer | LiteralInteger |
private | testUnlimitedNatural | 8 | |
PrimitiveTypes::Real | LiteralReal |
private | testUnlimitedNatural | 8.0 | |
PrimitiveTypes::Boolean | OpaqueExpression |
public | -testUnlimitedNatural=8 | ||
#testInteger=-6 | PrimitiveTypes::UnlimitedNatural | OpaqueExpression |
public | #testInteger=6 | |
protected | testInteger | 6 | |
protected | testInteger | 6.0 | |
public | #testInteger=6 | ||
-testReal=4.5 | PrimitiveTypes::Integer | OpaqueExpression |
public | -testReal=4.5 | |
private | testReal | 4.5 |
The Direct Editor Condiguration allow to define a new cirect editor for Papyrus. This define the object type to edit and the editor configuration class used for the integration of editor.
For the Value Specification XText editor, a default Direct Editor Configuration is already defined: ValueSpecificationXTextDirectEditorConfiguration
which allow to manage the type org.eclipse.uml2.uml.ValueSpecification
To redefine the default languages used by created OpaqueExpression
by the properties widget, a class extending the ValueSpecificationXTextDirectEditorConfiguration
must be created and the method getDefaultLanguages()
must be override.
Then, this created direct editor configuration must be referenced in the org.eclipse.papyrus.extensionpoints.editors.DirectEditor
extension point with a higher priority than the default (Lowest).
The context file allow to define the field available in the properties view. To define the field which will be displayed in the properties view with XText parser and completion, the UMLStyledTextReferenceDialog
will be used.
This class contains a UMLXTextReferenceValueEditor
which contains a StyledText
for the text fill and StyledTextXTextAdapter
to manage the XText parser and completion.
Here, an example of context and xwt file for the default value of property object:
In the PropertyEditor created, an attribute directEditorConfiguration
will be implemented to define the direct editor configuration class to use for the edited object:
The context file must be referenced in the org.eclipse.papyrus.views.properties.context
extension point:
A default cell editor configuration already exists for the Value Specification: ValueSpecificationCellEditorConfiguration
. But to get the possible XText parser and completion in cell of NatTable, the cell editor configuration must be extended and the created class must be referenced in the org.eclipse.papyrus.infra.nattable.celleditor.configuration
extension point with an inferior order than the others.
Here, an example:
A default cell manager already exists for the Value Specification: ValueSpecificationCellManager
. But to get the possible XText parser and completion in call of NatTable, the cell manager must be extended and the created class must be referenced in the org.eclipse.papyrus.infra.nattable.cellmanager
extention point with an inferior order than the others.
Here, an example:
by the cell editor, the method getDefaultLanguages()
must be overridden in the class extended from ValueSpecificationCellManager
org.eclipse.papyrus.uml.textual.editors.example
provide an example of integration of this editor in the table and in the property view to edit the default value of a property.
