Papyrus Banner
Overview and Video
This page describes the navigation feature of Papyrus implemented in Neon. The YouTube video guides you step-by-step in using the navigation feature. Sections below only describe succinctly the navigation feature.
Navigation Menus
By alt-hovering over an element, in a diagram or the model explorer, a menu pops up. This menu is called the alt-menu. The menu shows commands to navigate to some targets, which are related element or the hovered element itself (in another representation). When clicking on a command, corresponding to a target, we navigate to: (1) first representation of the target found in a(nother) diagram, or (2) the target in the model explorer if the first rule found nothing. The alt-menu also shows user-defined hyperlinks pointing to diagrams, local documents, or websites. The figure below shows the alt-menu:
Papyrus Navigation Alt-Menu
The goal of the alt-menu is to navigate quickly to a target, with the user having to go through too many choices. The user may also navigate by right-clicking on an element in a diagram or the model explorer. This opens up a context menu. He can then choose where to navigate to for a selected target. The figure below shows the context menu:
Papyrus Navigation Context Menu
The user may choose the available navigation targets in the preferences menu. The figure below shows some implemented targets:
Papyrus Navigation Target Preferences
Hyperlinks Proposition
When the user double-clicks on an element in a diagram, we navigate to its default hyperlink. If there aren't any default hyperlink(s), hyperlinks are proposed according to some pre-defined strategies. If there is only one proposed hyperlink, we navigate to it. If there are several, the user may choose one. The figure below shows the menu to choose a proposed hyperlink:
Papyrus Proposed Hyperlinks Menu
The user may choose the hyperlinks proposition strategies in the preferences menu. The figure below shows some implemented strategies:
Papyrus Hyperlink Preferences
Misc. UI Enhancements
Some other UI enhancements are implemented:
