Sections below show how to use the API to contribute to the navigation menus and hyperlinks proposition strategies.
Navigation API
The navigation API has the following:
- Interface org.eclipse.papyrus.infra.services.navigation.service.ExtendedNavigableElement
- Classes that implement this interface are navigable elements, i.e. something that wraps a semantic element, that let us navigate to some other object
- You probably shouldn't implement this directly, but the following class:
- Class org.eclipse.papyrus.uml.navigation.navigableElement.GenericNavigableElement
- A generic navigable element. Your own navigable element should probably extend this class, unless you know what you are doing. :)
- Extension point org.eclipse.papyrus.infra.services.navigation.navigationContributor
- Specify extensions that will contribute navigable elements
- Interface org.eclipse.papyrus.infra.services.navigation.service.NavigationContributor
- Classes that implement this interface contribute navigable elements
- The "getNavigableElements(Object)" method returns navigable elements according to the context represented by the object passed as parameter. (You do not need to handle how to pass the object, only what to do with it)
Step-by-step Guide
The following instructions allow you to create a new hyperlink contributor:
- Create a plugin
- Add the following dependencies to MANIFEST.MF:
org.eclipse.papyrus.infra.gmfdiag.navigation
- Create a navigable element:
public class SpecialTargetNavigableElement extends GenericNavigableElement {
public SpecialTargetNavigableElement(/*...*/) { // Write a constructor that will call "super(Element elt)" where "elt" is the semantic element that this navigable element wraps
super(/*...*/);
public String getLabel() {
return "Go to special target" + getElementLabel() + "..."; // The convention is to return a string like this
public String getDescription() {
return "Go to the special target:" + getElementLabel(); // The convention is to return a string like this
// You can also overwrite other methods of GenericNavigableElement
- Create a navigation contributor:
public class SpecialTargetNavigationContributor implements NavigationContributor {
public List<NavigableElement> getNavigableElements(Object fromElement) {
List<NavigableElement> result = new LinkedList<NavigableElement>();
/* You can check if fromElement is a particular UML type for example.
You can then add instances of "SpecialTargetNavigableElement" to the list
of navigable elements that will be returned. What you wrap with
the navigable element is up to you. Usually we wrap an element related to
fromElement. */
return result;
- In plugin.xml, add the following extension:
- Right click > New > contributor
- Fill info
- Id: an arbitrary string
- Contributor: reference to the class that will contribute navigable elements. Example: "SpecialTargetNavigationContributor" created beforehand.
- Label: how this contributor is displayed in preferences (for activation/deactivation)
- Description: tooltip displayed when the mouse hovers over this contributor in the preferences
- (Optional) Activate/deactivate a hyperlink contributor programmatically (example for "SpecialTargetNavigationContributor" whose id is "oep.specialTargetNavigationContributor"):
IPreferenceStore preferences = Activator.getDefault().getPreferenceStore();
String key = "oep.specialTargetNavigationContributor" + ".isActive";
preferences.setValue(key, true); // or false to deactivate
Real Example
An example of a hyperlink contributor is available below. This contributor creates automatic hyperlinks for a class that has inner classes shown in its inner class diagrams.
- /org.eclipse.papyrus.uml.navigation/src/org/eclipse/papyrus/uml/navigation/navigableElement/TargetNavigableElement.java
- /org.eclipse.papyrus.uml.navigation/src/org/eclipse/papyrus/uml/navigation/navigableElement/RelationshipNavigationContributor.java
- /org.eclipse.papyrus.uml.navigation/plugin.xml (line 48)
Hyperlink API
API Overview
The hyperlink API has the following:
- Extension point org.eclipse.papyrus.infra.hyperlink.hyperlinkContributor
- Specify extensions that will contribute hyperlinks
- Interface org.eclipse.papyrus.infra.hyperlink.service.HyperlinkContributor
- Classes that implement this interface may contribute hyperlinks
- The "getHyperlink(Object)" method returns a list of hyperlinks according to the context represented by the object that is passed as parameter. (You do not need to handle how to pass the object, only what to do with it)
Step-by-step Guide
- Create a plugin
- Add the following dependency to MANIFEST.MF:
org.eclipse.papyrus.infra.gmfdiag.hyperlink
- Create a hyperlink contributor:
public class MyHyperlinkContributor implements HyperlinkContributor {
public List<HyperLinkObject> getHyperlinks(Object fromElement) {
ArrayList<HyperLinkObject> hyperlinks = new ArrayList<HyperLinkObject>();
You can use the org.eclipse.papyrus.infra.services.viewersearch.impl.ViewerSearchService
to search views containing a particular semantic element.
See Real Example section for an example on how to use the ViewerSearchService */
return hyperlinks;
- Fill info
- Id: an arbitrary text
- Contributor: reference to the class that will contribute hyperlinks. Example: "MyHyperlinkContributor" created beforehand.
- (Optional) Activate/deactivate a hyperlink contributor programmatically (example for MyHyperlinkContributor whose id is "oep.myHyperlinkContributor"):
String key = "oep.myHyperlinkContributor" + ".isActive";
preferences.setValue(key, true) // or false to deactivate
Real Example
- /org.eclipse.papyrus.uml.diagram.clazz/custom-src/org/eclipse/papyrus/uml/diagram/clazz/custom/hyperlink/InnerClassHyperlinkContributor.java
- /org.eclipse.papyrus.uml.diagram.clazz/plugin.xml (line 1733)
Bugzilla References
