Here we will list all changes between Papyrus 4.8.0 (Eclipse 2020-06) and Papyrus 5.0.0 (Eclipse 2020-12).
Plugin dependencies
To ease Papyrus developement, we remove all reexported dependencies from the Manifest file.
Changes
Here the list of API changes for each plugin.
org.eclipse.papyrus.infra.architecture
- bug 565361
MergedArchitectureDescriptionLanguage
- new method
getTreeViewerConfigurations()
org.eclipse.papyrus.infra.core.architecture
- bug 565361
- new abstract class in the
architecture ecore model:
- concret implementation can be found in the new plugin
org.eclipse.papyrus.emf.facet.architecture, see class
EMFFacetTreeViewerConfiguration
ArchitectureDescriptionLanguage: new field
treeViewerConfiguration
org.eclipse.papyrus.infra.nattable
- bug 517617 and bug 532452 (ensure the selection don't change after some user actions)
We change the storage of the current selection, but we keep the algorithm provided by
TableSelectionProvider, but we change the manipulation and the storages of the informations.
- new method
setActive(boolean) to allow to listen or not the selection changes
TableSelectionWrapper
- new constructor
TableSelectionWrapper(final INattableModelManager manager, final SelectionLayer selectionLayer, final Collection<PositionCoordinate> selectionCells),
all others are deprecated and will be removed.
- new methods
updatePositions, to update position of referenced elements (rows/columns/cells) after a refresh
- new methods
buildSingleCellSelection,
getSelectedElements,
getSingleSelectedCells,
addSelectedRow,
addSelectedColumn,
removeSelectedRow,
removeSelectedColumn,
copyRowsSelection,
copyColumnsSelection
- methods
getFullySelectedRows and
getFullySelectedColumns changed without breaking API: before the returned map used the row index as key, and now this same map use the row position as key. To obtain the row index, you must call
selectionLayer.getRowIndexByPosition
- bug 486733
PapyrusNatTableComparatorChooser
- change visibility from protected to public for method
rebuildComparator
org.eclipse.papyrus.infra.ui.emf
- bug 565361
Activator
- remove public field
CUSTOMIZATION_MANAGER_SECTION -> now defined in the new class
WorspaceCustomizationUpdater as protected
- method
restoreDefaultCustomizationManager has been renamed into
resetToDefaultCustomizations
Behavior changes
- bug 565361:
- The EMFFacet Customizations applied in the ModelExplorer are now defined in an ArchitectureDescriptionLanguage (Architecture file). If not, we continue to apply them using their plugin.xml declaration.
- When the user changes the customizations to apply (using the ModelExplorer action), this change is now associated to the current edited model
- As we define EMFFacet customizations in Architecture File and we associate user changes to an Papyrus model, the list of applied Customizations is now updated each time the user edit a new model.
- The applied Customizations are also updated when the user change the ArchitectureDescriptionLanguage to use it is model, to be consistent with the current language.
- A button to reset the applied Customization to the initial definition has been added to the ModelExplorer toolbar.
